(点击题目可以在互联网中搜索该题目的相关内容) 日期:2006-11-27 23:48:00 来源: 作者: 点击: | |
i have an application where we would like to have the ability to do programming changes on a PLC via a modem (Allen Bradley SLC 5/05, if it makes a difference). However, we dont have a telephone line available. Does anyone know of a manufacturer that makes a modem that functions using wireless (that is, cell phone) communications? we have apply this system. we use ip static to remote monitor ( we use leased line via- fiber optic and satelite, we think cheaper than via cellular phone. ) slc plc, for prgrammning and monitor the data, then logging data to our central server. for remote terminal we use 1 pc server with linx gateway to acces plc from central server. pc central we use rslogix500 , rs view and linx. pc remote ( direct to plc ) use rslinx gateway. gateway addres of plc use address of remote pc. why we use pc remote? because some times our technician visit the remote plc for check or maintain. then we use pc remote to for temporary logging data, so our central server not work heavily with raw data from plc. for all applicartion, land line or cellualar we think, best use static ip. because setting of linx more secure and safe if use static ip than diynamic. the difficulty ( because i am not a satelite man ) when we 1st time to make route to plc remote from central server. ) best if you need advice from your line provider to connect from central in order to acces plc ip number. the summary of our work to connect 1. make route from pc remote to plc. via comand com of windows xp 2. make route from pc remote to pc server( ask to satelite man, faster than try by oursef), idem 3. sett gateway of plc to ip pc remote. than 4. set all linx setting to connect each other. 5. get conected from you central to plc. Just done this myself and so have gone through the headache. There are two main types of connection, remote initiated and remote terminated. Remote initiated means the remote device makes contact with you, remote terminated is where you want to make contact with it. Remote initiated is the easiest from an IP address point of view, in the same way that your PC can have any address on a LAN that is connected via a router to the internet, the remote device can have any IP address. But you need remote terminated, this means that you will need to know and have access to the remote devices IP address. 本新闻共2页,当前在第1页1 2
上一篇: PLC在国产高压大功率变频器中的运用 下一篇: PLC和PC-based技术特点和优势对比 |
