CLX5555 to INVIEW display using Ethernet IP woes-PLC技术网(www.plcjs.com)-可编程控制器技术门户
下载中心导航三菱 西门子 OMRON 施耐德
GE FANUC 松下 贝加莱 keyence 爱默生
富士 Rockwell 台达 LG 和利时 横河 永宏
浙大中控 浙大中自 凯迪恩 LS_hermes 安控
无锡信捷 兰州全志 SIGMATEK OEMax ABB
基础资料 项目资料 工具软件 更多
PLC行业应用导航:
PLC技术网
PLC论坛
博客地带
工控商城
搜索中心
日期:2006-11-27 23:48:00     来源:   作者: 点击:
Im having some problems getting a AB Inview display talking to a CLX5555 processor.
Hardware is as follows, Logix 5555, Ethernet ENET/B card, through a switch to the 2706-PENETM module mounted on the inview display.
I have sucessfully setup the ip address for the PNETM with the serial cable and i have changed over to the industrial comms and the signs appearing in RSLINX
I can succesfully upload new messages to the sign, change comms setting in the sign and trigger messages using the inview software.
Ive setup a program to trigger the messages in the processor which is running happily.
BUT im getting no update on the sign when its triggered by the processor.
Has anyone setup one of the ethernet IP ones and got it to work? We have a DH+ one going and that was relativly straight forward.
Ive got a couple of them running - basically followed the example.
I assume youve ocnfigured the IP address of the controller (with path) in the PENET box as well as the IP address for the box itself. Also entered valid trigger tags and message array tags.
The PENET needs to see a 0 to 1 transition in the trigger tag. I think the minimum sample time is 100 msec. so the trigger needs to be in each state for at least 200 msec.
During some recent mods on one of mine, where I had to change the target processor, the unit wouldnt work until I cycled power.
Yes ive set up the data path
10.55.178.41 is my eneb (Control logix 5000)
node path is 1 (backplane) 0 (processor in slot 0)
10.55.178.45 is my inview
subnet 255.0.0.0
I think my problem might be the string im using.
The example that come with my sign said to use this
^T[message number]^M
i think it should be $14[message number] <-- forgotten the end bit
本新闻共2页,当前在第11 2
上一篇: PLC通讯控制伺服电机
下一: SLC 500/RSLogix 500 Communications
迅闻自动化工程部声明如下:
网站备案号:粤ICP备13021460号-1
网站法律顾问:ITLAW-庄毅雄律师
51La
